Seemore's avatar
Seemore
Engine battery not connected to anything.????
My engine battery is charged and good. But, I get zero juice to anything from the ignition switch. The headlights don't come on either, which should work with out the ignition. When using the emergency switch ( the coach battery) everything works as expected and the engine starts . I have cleaned the terminals and connections at the battery.Where should I start looking for the problem? I have a 2000 Coachmen Mirada 300QB. It has the Ford V-10 engine.
