Enablethen,
It's a xantrex digital echo charge 12/24 volts unit. Small right behind the house batteries. There's a "dimensions" inverter in the cabinet that does power the tv
I think the only purpose of the dimensions inverter is to power the tv's when using house batteries and doesn't have anything to do with the xantrex unit, but not sure.
The xantrex unit s flashing I think because the engine battery is only at 12 volts. I pulled it and trickle charging it.
What I am curious about is, if that xantrex unit is supposed to maintain charge on the house and engine batteries but what sources it? Shore power or something else?
Thanks in advance
