wolfe10
Mar 16, 2016Explorer
YC 1 wrote:
It would not take much to install a solenoid activated by a wire that is hot when the ignition is on. Or if you have an aux start switch that works just run an ignition wire to that solenoid.
MAYBE!
If it is a CONSTANT DUTY solenoid, that could work.
But many boost solenoids are only intermittent duty and certainly not designed for constant duty.
38,782 PostsLatest Activity: Aug 23, 2026
