dougrainer
Mar 16, 2016Nomad
YC 1 wrote:
It would not take much to install a solenoid activated by a wire that is hot when the ignition is on. Or if you have an aux start switch that works just run an ignition wire to that solenoid.
That is what the Intellitec BIRD system does with a small control box. They use the same solenoid and depending on if the IGNITION wire is powered is how that module activates the solenoid. Doug
38,782 PostsLatest Activity: Aug 23, 2026
