YC_1
Mar 16, 2016Nomad
dougrainer wrote:YC 1 wrote:
It would not take much to install a solenoid activated by a wire that is hot when the ignition is on. Or if you have an aux start switch that works just run an ignition wire to that solenoid.
That is what the Intellitec BIRD system does with a small control box. They use the same solenoid and depending on if the IGNITION wire is powered is how that module activates the solenoid. Doug
Yes, I am totally familiar with the BIRD systems. However if the op system never charged it is a simple task to add a solenoid. I have installed thousands of solenoids in 40 years in my business. I kept them in stock by the box full.
38,782 PostsLatest Activity: Aug 23, 2026
