dougrainer
Mar 16, 2016Nomad
YC 1 wrote:
It would not take much to install a solenoid activated by a wire that is hot when the ignition is on. Or if you have an aux start switch that works just run an ignition wire to that solenoid.
You run that Ignition wire to the COLD side of that Dash Boost switch. A LOT easier and a shorter run. Doug
38,782 PostsLatest Activity: Aug 23, 2026
