Fishinghat
Aug 25, 2014Explorer II
wolfe10 wrote:
Stop. There are two very different questions here:
IF your question is: "I am changing coolant, what do you recommend", I agree, one of the new-generation OAT-based coolants is the way I would go. If Cummins, would go with their house brand which is Fleetguard ES Complet OAT. If Cat, Caterpillar ELC.
IF you question is what to I top off my present system with, you need to check with your chassis maker (Freightliner I suspect). BUT, if this is OE coolant, you are way over-due to change it, as you do not have one of the long-life coolants from the factory.
X2
Do what Brett suggests. He really does know his "stuff".
38,782 PostsLatest Activity: Aug 31, 2026
