jeromep
Apr 24, 2021Explorer II
Larrysr1957 wrote:
I have a 97 ford 460 that has an idle surge and sometimes stalls when stoppingat traffic signals or signs. The mechanics has replaced the throttle positioning sensor and the idle air control and cleaned the fuel system. The idle rpm's still surges.there are no codes. Any help is appreciated
I think you need to find a different mechanic. They are just throwing replacement parts at the problem, they don't really know what is happening. If they knew what was happening they would have already fixed it. I really don't like it when mechanics throw parts at a problem and you pay for their experiment.
I don't know what the issue is either, but my advice costs you nothing and if I were in your position I'd be more than just a little annoyed at paying for something to not be fixed. But I do know this, 97 was the last year of the 460 on a vehicle chassis. For MY 1998, the V-10 was introduced and a totally new era of computer control was introduced.
The 460 was never built in an OBD or OBDII equipped vehicle, therefore getting codes out of it for diagnostics requires much older hardware. They are technically Ford EECIV (Electronic Engine Control 4), vehicles. Ford used EECIV in just about everything from like 1982 all the way till the OBD era. EECIV had numerous changes and variations over all those years and the computer unit was basically entirely different from vehicle to vehicle. My guess is that only a Ford dealer, or a very well equipped independent shop, will have the proper equipment, probably sitting in a corner or on a shelf, to get the codes and information that might lead to a direct fix. If you can find a dealer or mechanic with a Ford SBDS (Service Bay Diagnostic System) with the 168-pin connector, which is probably what your 460 has to connect to the onboard systems, they might be able to find out what is occurring, assuming that the on board sensors are able to identify an issue.
My point is that if you have a mechanic that is throwing parts at the problem, they don't have the right equipment to complete a diagnostic.
