Anyone know what kind of oil is put into a 2014 Coachmen Mirada. I do not know if it is regular oil or synthetic. Does it matter if I switch it to regular oil. Is there a place in the coach that say...
The good news is that total synthetic oil and regular oil are 100% compatible. Not only can you switch to one or the other, you can even add one to the other if the oil level is low. This means that whatever was put in the engine by Ford, as long as you put the recommended weight oil in the engine, the choice is totally up to you.
