allbrandauto wrote:
sometimes weak battery can cause this problem it doesn't have a throttle cable its drive by wire if the gas pedal sensor and the throttle position sensor don't match up it will throw meesedge and go into default mode charge your battery and see what happens
x2.
Those days every driver should have OBD scanner under the seat.
Modern engines seldom have major break-downs, but maze of sensors can trigger CEL.
It is unknown that will kill your confidence, so once you scan the code to a stupid sensor, you will be confident to continue the trip.
