mkguitar
Aug 16, 2015Explorer
and...for an emergency situation...
TURN OFF air conditioning-
and in real trouble turn on the heater full blast- the heater core is just like a radiator and blowing air through it will remove heat from the coolant...of course the vehicle will get hot inside...so open your windows- this could save your motor in a real emergency
IF adding water to your cooling system, only add slowly into a RUNNING motor, that way the cooler fluid is distributed slowly. a LARGE temperature differential can crack your block.
mike
mike
38,782 PostsLatest Activity: Sep 02, 2026
