Ha heating problem on a previous coach while coming over the Bighorns. Before we had a long breather tube installed, I stopped at a quarter carwash and sprayed degreaser on the radiator and then used the soap washer to push as much through as we could get. Washed out straw (not as much as a birds nest, but something I suspect was picked up driving through a maintenance area with mowers) Lot a nasty, greasy water washed out as well. We repeated this a couple or three times and the system ran cooler. We had Freightliner in Gaffney add the tube and steam clean the radiator - no more problems
