koda55 wrote:
As an over the road truck driver, when climbing mountains I always down shifted to keep my rpms high. This kept more coolant flowing and never over heated.
While I agree 100% with the "keep RPM high IF, repeat IF overheating", it also uses more fuel and for any modern turbo inter-cooled engine (Cat, Cummins, DD 4 strokes, etc), please read your manual for most economic way to climb a grade.
It is at lower RPM-- down to peak torque RPM, NOT at high RPM. Yes, if temperature starts to rise, then go to "Plan B" which will remove more heat from the engine AND more $$$ from your wallet.
We just climbed Powder River Pass (9,500'+-- climbing from 4,200'). 4th gear at 1,600 all the way-- no overheating. Others, the same day, same engine ran at 2000+ RPM all the way. Guess who uses less fuel???
If you have a Detroit two stroke, please DO keep RPM up, as they were NOT designed to run under load at lower RPM. And, I suspect these older engines were the source of "Keep RPM's UP".
