enblethen
Jun 12, 2013Nomad
Take the fuel line loose at the genset, blow toward the fuel tank, listen to see if you hear it bubbling the gas. I would say the fuel line has rotted away above the fuel tank.
You could use a short piece of hose into a fuel can to see if the genset set will run that way. Temporary only.
