Geocritter
Apr 11, 2015Explorer
enblethen wrote:
I would verify the arm length. My engine sits quite aways back behind the hood. If you are pulling engine and transmission at same time with arm extended it may be too heavy.
Summit Racing
Oddly enough my transmission seems to be okay (knock on wood) it's always shifted well and doesn't leak at all. My plan is to just remove the engine, leaving the transmission and torque converter in the vehicle.
You bring up a good point and when I rent the engine crane I'll be certain to measure the distance taking balance/fulcrum points into account.
Steve
38,782 PostsLatest Activity: Sep 01, 2026
