RLS7201
Apr 11, 2015Explorer II
If you remove the cross brace that the air cleaner box sits on, you should have about 3" of clearance for the engine to come forward. Measured from the bottom of the pan to the top of the valve covers. If you remove the upper manifold, valve covers and rocker arms, you should then have plenty of clearance for the cherry picker (engine crane). I'll be addressing the same issue this fall when I change out my 1995 F53 460.
Keep us posted
Richard
Keep us posted
Richard
38,782 PostsLatest Activity: Sep 01, 2026
