Geocritter
Apr 13, 2015Explorer
RLS7201 wrote:
If the AIR (Air Injection Reactor) is blowing into the exhaust manifolds, you should have the EFI manifolds. Older carb engines had the AIR blowing into the heads.
Richard
Thanks Richard, some good news finally, it looks as if I do have the original EFI exhaust manifolds bolted up to the earlier style replacement heads. BTW I found the old pinched-off head-mounted AIR tubes on the rear of the cylinder heads, further assuring the fact that they are earlier model carb heads.
Steve
38,782 PostsLatest Activity: Sep 01, 2026
