turbojimmy wrote:
Foiler wrote:
Has a driver side door but not sure the doghouse will let me pull it out
from the top, maybe with the heads removed, will have to do some
measuring if it comes to that. Don't think there is any way it could come
out the front.
Hopefully you'll find it's an issue that can be fixed with the engine in place.
If the engine does have to come out, hopefully it will come out the doghouse. It was tight, but mine went through the door and through the hole in the floor with the heads on it (valve covers too). The boom for the hoist reached the engine through the driver's side door. I just had to remove the left front tire so the legs on the hoist could get under it.
How is your running jimmy.
