Foiler
May 18, 2016Explorer
Engine replacement
Had a 460 in a 96 class A go bad this Spring. Leaking and smoking, 2 qts. in 50 miles. Ford doesn't make this motor anymore, everything I have is obsolete. Not just anyone can do a swap in a gasser RV. Not sure of much except that it looks expensive.
At a Ford dealership now, they are evaluating the problem. Pretty sure they will have to overhaul the engine which I assume means removing it, looks like a difficult job.
Not sure if they would put a crate motor from a rebuilder, like Jasper.
Anyone have any experience with this issue?
Thanks,Terry
Thanks,Terry
