IAMICHABOD
Dec 07, 2014Explorer III
As stated before "it depends".
There are some brands that come from the factory with them already installed,Fleetwood products such as mine and some Winnebagos come from the factory with a BIRD a Bi-Directional Isolator Relay Delay
It charges both batteries when either one is
being charged. When the coach is being driven,both
batteries will be charged from the engine's
alternator. When the coach is plugged into shore
power,both batteries will be charged from the
converter. If neither battery is being charged, the
batteries are fully isolated. The controller also
senses heavy loads on either battery to prevent
the wrong battery from being inadvertently
discharged.
In your search for that RV it would be something to ask about.
While sitting even while plugged in, if some type of charger is not hooked up to the Chassis battery it will go dead from the parasitic loads.
discharged.
38,769 PostsLatest Activity: Apr 03, 2026
