DOTLDaddy's avatar
Dec 07, 2014
Engine starting battery being charged while parked?
I do not presently own a class A, but maybe someday . . . :@
While parked for an extended time, how does one keep the engine starting battery charged? I know the house batteries are kept charged via shore power, but does that also take care of the starting battery?
:h
  • All of your remark and question is an open discussion.
    Some coaches don't do a good job of caring for the house bank when on shore power. That can be fixed with a good converter/charger. Once you know you have a good converter/charger, then there are numerous devices that can connect the house bank to the main engine start battery and keep it properly maintained. They are not expensive, but I have not yet seen a production coach equipped with one as standard equipment from the factory.
    Matt
  • As with so many things, "It depends"!
    It depends on how the coach is wired. It depends on what modifications a previous owner may have made.
    I have heard that SOME brands of coaches are wired so the converter charges the chassis ("engine starting") battery. I have owned a Pace Arrow, a Tioga, a Southwind, all by Fleetwood, ranging in year from 1977 to 2002.
    I also owned a 1988 Suncrest (an "orphan" brand).
    NONE of them were wired so the chassis battery charged from the converter.
    None were wired so the chassis battery powered the house electrical system.
    I have rarely had a problem with the chassis battery being discharged from sitting for up to 13 weeks. Several months, yes, the parasitic loads are enough to drain the battery.
