Still have not found the problem. The engine starts everytime I have turned the key. Going to run me hot wire from the battery thru a fuse block into a push button switch and then to the solenoid to use as an emergency way to start the engine until I can find the problem. All of my connections are clean and tight. And the engine starts just fine right now. Going to keep on looking for the problem, but as we all know intermittent electrical problems can be hard to find. Thanks for all of the input and please keep it coming.
