Wildman you are right after two days in a Walmart parking lot shock set in, then despair when I could not find a shop to take me in for a week. I had a bad experience 3 years ago when someone on here recommended a shop and I could not get in so I went by that shops recommendation. I was having a clunking noise in the front end that I could not figure out they told me it was the coil spring need to be reseated and my front end looked good and charged me $380. In Ohio the upper left ball joint broke and the whole front end came crashing down. It happened on a ramp and I was going about 30 mph. I was just thankful it did not fail coming down the mountains of Colorado. Shop in Ohio that my insurance co. found for me installed the wrong ball joint again and had to be changed when I got back to CT. So finding the right shop in an unfamilar place is inportant. The only problem now is my generator does not start and I see no fuel in the filter when I crank it I hope they did not pinch a line when they reinstalled the tank.
