Gjac's avatar
Gjac
Explorer III
Jul 15, 2017
Engine stubbles at idle speed
The MH in my signature has become Ihard to start and falls flat when I give it the gas. The problem seams to be progressing. Changed fuel filter before trip, ran can of seaform. Still does it when it's hot. Runs normal once im driving.
  • On left side of throttle body, is the Idle air control valve. It acts like a coke. It is possible that the connector is off or passage is plugged. Very small screws that break easy. Not a good thing to work on on the road!
    Next possibility is bad plug wire(s), cap and rotor
  • Gjac's avatar
    Gjac
    Explorer III
    No codes sprayed all vaccum lines on upper engine block no increase in rpm.
  • Look everything over on the engine. At that age you may have a rotted hose. Be gentle.
  • Sounds like a vacuum leak!
    Mass air flow sensor?
    Any codes? No codes more apt to be vacuum leak.
    1996 P-30 8.1 TBI or port injection?
  • Gjac's avatar
    Gjac
    Explorer III
    rjxj wrote:
    Be sure fuel pressure is correct first
    I am on the road out west and have no gauges, if I floor it up a hill it is getting gas and runs well so I think fuel pump is fine. If I put it in neutral at a stop light idle is good and stumbles slightly when put in gear.
