Coach_Cleats's avatar
Coach_Cleats
Engine temp wire/switich sending location?
Engine dash Temp gauge on my Cat 330, 3126 sn# KAL24391, does not register/move any longer. I've looked at engine from the top for wire or sending unit but not sure what is what.
Any info greatly appreciated.
  • I had a Winnebago with a CAT 3126B engine and there were two wires on the temperature sender on the engine. One of them got disconnected somehow and the temperature gauge did not work. Once wire was reconnected, problem solved.
    pete
  • Might help maybe? I think right engine?
    For better view click once, then after it opens click again, should be big enough to get good view at stuff
  • The dash coolant temperature gauge sender is installed by your chassis maker.
    So, check with Monaco for location and part number. But, before replacing, be sure the connection at the sender is clean and tight.
