rgatijnet1
Dec 26, 2015Explorer III
Spark plug wires and it could also be water that was ingested in to the air intake and has soaked the air cleaner paper element. Did you drive in the rain?
The spark plug wires are a fairly common problem and a good set of silicone wires, WITH the heat shields, is a good solution.
The fuel filter can be accessed from underneath and it is within a foot of the fuel tank along the frame rail. Yours uses a special filter that is hard to find and expensive. The do make an adapter that will replace the special filter and allow you to use one that is readily available at most auto part stores.
