Racorman's avatar
Racorman
Engine will not Start... Trouble shooting help requested
I was in Utah on vacation when my V-10 gas motor in our 2012 Itasca motor home suffered a catastrophic failure with 19,000 miles on it. Ford replaced the motor under warranty with a long block engine assembly.
I drove home to Northern California and put 1000 miles on the new motor. The Ford dealer in Utah did a great job and the motor is tight as a drum as it didn’t lose a drop of oil on the return home trip.
However, as soon as I got home I find that I cannot start the engine with the chassis battery and have to use the dash mounted coach battery boost button to start it.
1. The chassis battery is fully charged at 12.7 volts
2. The chassis battery rocker switch next to the entry door will not activate (no click or green LED light)
I’d prefer to fix the problem myself as opposed to taking it to the dealer for repairs and would appreciate some help in troubleshooting the problem. Has anyone else experienced this problem?
1. Are there dedicated chassis fuses that I should check?
2. Could the transfer switch, operated by the chassis battery rocker switch, have failed?
3. Is there any possibility that when the engine was replaced, the mechanics failed to properly attach wires to the starter?
4. Are there any other troubleshooting tips that can be looked at?
Many thanks
