krivanj
Nov 06, 2015Explorer
Need more info... Did you start it to leave the repair shop or was it running?
If it was running, maybe a ground off the battery?
Start at the battery and follow it to the boost switch. Then check the grounds... What does the charge gauge show when it is running.
Put w voltmeter on the chassis battery while running and see if the alternator is charging the battery. Should be 13 or more volts...
38,763 PostsLatest Activity: Dec 05, 2025
