FIRE_UP
Apr 22, 2015Explorer
Coach Cleats,
Well Sir, it might be a bit tough to answer your question accurately due to the fact that, your step cover, may not work the same as others. There used to be air controlled ones. Then, they progressed to electronic ones. Ours is the first year electronic ones. The motor in it is almost the same exact motor that runs the outboard steps and, many door awnings.
Many of those are controlled by amp draw, not limit switches. As the motor moves its object, in this case, your step cover, it draws a very slight amount of amps. But, once the step cover hits the end of its travels, at either end, the amp draw spikes up, instantaneously. When that happens, there's a circuit in there that reacts instantly and shut's down the motor.
And, in many or, most of those step covers with that kind of system, there is a cable that is attached to a drum, that is attached to the steps. Now, is it possible for that cable to have been disabled? Yep, there's a definite possibility. Can that cable break, well, yes that can happen too. Not very often though. But, you'll have to dig up in your packet of books that came with the coach, to see what the MFG of the step cover is and, if there's any trouble shooting charts. Good luck.
Scott
Scott
38,766 PostsLatest Activity: Jan 10, 2026
