gstell
Apr 07, 2013Explorer
sailor_lou wrote:
I have never seen any manufacturing drawing either, but after looking at the configuration I believe plootsa is on the mark. However, I would start by using a rubber strap wrench to hold the piston because even the slightest scratch or dent in the ram will cause it to leak forever. Good luck and let us know how you make out.
Lou
05 Travel Supreme Envoy
Tried a rubber strap wrench, and still couldn't tighten down the bolt. I plan to try and rig a stand to drop the jack on to with 4 X 6's and this will allow me to get the wrench under the jack and maybe the slight pressure on the rigged stand with keep the piston from turning.
