dougrainer
Apr 30, 2018Nomad
Fluid level will not affect a HWH slide system. The fluid is static in EACH slide. All the existing fluid does is move to the other side of the pistons. Besides, fluid level on ANY slide will not affect the PUMP operating. If low on fluid the PUMP will still HUM LOUD, it will not push fluid IF low. Possible you have a bad PUMP relay. But, that is odd, because the other HWH slides and jacks operate if done first. Doug
38,782 PostsLatest Activity: Sep 21, 2026
