MagillaGorilla
Jun 12, 2015Explorer
I would imagine that it would NOT be very easy to back a boat down a ramp with a MH. Most boat ramps that I see are not designed for the gigantic turning radius that a MH requires. Another issue would be the distance from the front axel to the rear axel to the hitch. This could cause quite an angle. Your front axel would likely be on flat ground while your rear axel would be on the ramp. That would cause a triangle at the hitch.
38,777 PostsLatest Activity: Jun 03, 2026
