tmaxx wrote:
Should this be a deal breaker? It seems that most Class C's that I have looked at have had water issues.
There are always several active threads with photos where someone is repairing water damage. Look at the photos of the damage that was found behind the visible walls.
Then the question that YOU need to answer is: "How comfortable am I that the leak was corrected
before it created the conditions that cause this type of problem ?"
If you are not 100% certain, then keep looking. Now that you have identified a floor plan that works for you, the search becomes much easier.
