terryflt's avatar
terryflt
excellent cooling system repair
Hi
2008 HR Ambassador 40 SKQ 360 DP
What started as a bad day got extremely better when we found a rad repair shop in Moncton New Brunswick. I noticed a leak out the back after seeing the temp gauge creep up. Filled up with water and proceeded to Moncton. Looked up on the GPS and came across
Multi Radiator Services. We called and were told to come right in. Within 15min the tech was searching out the leak. What was first thought to be the rad turned out to be the small return lines. Leo then proceeded to replace them. Good thing he was average sized.Not much room in there. Anyways 2 hrs later we were back on the road.
Couldn't have stopped at a better repair facility. Fast, honest and good work ethics.
If any one is in need of coolant repairs then I highly recommend
Multi Radiator Services Ltd
505 Macnaughton Ave
Moncton NB
506-859-8811
Terry
  • edm3rd: I must have used poor wording because I earnestly support spreading the word about good repair shops. I was just bemoaning the fact that good shops seem to the exception rather than the rule.
  • DougE wrote:
    Isn't it sad that we now heap praise on a mechanic that just did his job correctly and efficiently!
    I disagree. Personally, thanks to the OP for letting the rest of us know of satisfactory service. I believe it is just as important as letting people know of a bad experience.
  • In todays society, I think it's more about finding someone who is honest. That's sad!
  • Isn't it sad that we now heap praise on a mechanic that just did his job correctly and efficiently!
  • Glad it was simple....those lines that run from the overflow tank are tough to access to replace. One goes to the turbo. In the future, there is a large 1 1/4" hose that comes out of the bottom of that tank that should be replaced on your 08. Napa carries the hose...it's a green strip hose and sometimes hard to find.
  • Hi Terry,
    There is a website for rv repairs. That may be a better place to post your experience.
    http://rvservicereviews.com/
