John_Wayne
Apr 09, 2014Explorer II
Check the lenght of the break away cable. put the veh. behind the TV and just hook up the safety chains or cable. Now push the toad back till the chains/cables are tight. The break away cable should be about 4 to 6 inches shorter then the stretched out chains/cable. So if something does happen to the hitch the toad brakes will be on and slowing you down and you can stop with out the toad running into the back of you.
38,763 PostsLatest Activity: Dec 25, 2025
