Billinwoodland
May 06, 2015Explorer
10forty2 wrote:Billinwoodland wrote:
My coach is a 2008 with the Onan 5500 gas generator. The generator hours are very low, maybe 75 hours. I've had the coach less than 6 months. I was going to go through some basic maintenance, change out the plugs, fuel filter, oil and filter, and air filter. I have no idea when this was done before I bought the coach. How often do you guys do this type of maintenance? Is there something else I should be doing? I don't have the manual, need to buy one as it did not come with the coach.
Thanks
Bill
If you don't know when the last time it was done, then it's probably a good idea to go ahead and change out all that stuff and get a fresh start. Then, if you use the genny a couple of times a year along with monthly maintenance runs, you'll probably be good with an oil/filter/plug change every year. If you run it in a particularly dusty area, you may want to change the air filter more frequently.
That sounds reasonable. Thanks!
Bill
38,782 PostsLatest Activity: Sep 20, 2026
