Hank_MI
Jan 05, 2017Explorer
Starting the motorhome, gas or diesel not recommended. Onboard generators, it is recommended. Not to exercise the engine but to warm up the gen, dry it out and remove any corrosion from the brushes.
It's almost impossible to heat the crankcase oil up to operating temp by idling the engine. The coolant will heat up but without a load on the engine the oil won't. The oil typically get's hotter than the coolant when the engine is under load and that dries out any moisture. At idle it just doesn't happen and you just add more moisture.
38,766 PostsLatest Activity: Jan 10, 2026
