Bill_Satellite
Jan 05, 2017Explorer II
msmith1199 wrote:
There's some advice that's all over the board!!
While this ^^^^ is not helpful ^^^^^, the reality is that you should NOT "exercise" (start) your engine while parked. You need to drive the RV 25+ miles if you plan to start it. If that's not in the plan then there is no reason to start the engine.
It's likely also not necessary to run the genset while parked but if you do then you should load it up to about a 50 percent load and let it run for an hour or so. Unload it, let it cool down for a few minutes and then shut the generator down with no load.
38,766 PostsLatest Activity: Jan 10, 2026
