msmith1199
Jan 06, 2017Explorer II
Bill.Satellite wrote:msmith1199 wrote:
There's some advice that's all over the board!!
While this ^^^^ is not helpful ^^^^^, the reality is that you should NOT "exercise" (start) your engine while parked. You need to drive the RV 25+ miles if you plan to start it. If that's not in the plan then there is no reason to start the engine.
It's likely also not necessary to run the genset while parked but if you do then you should load it up to about a 50 percent load and let it run for an hour or so. Unload it, let it cool down for a few minutes and then shut the generator down with no load.
Mine is not helpful but getting advice that is everything from let it sit for 5 years and don't worry about it, to start it every 30 days and drive it 100 miles, is helpful?
38,766 PostsLatest Activity: Jan 10, 2026
