Matt_Colie
Jan 07, 2017Explorer II
Please listen to me when I talk about this subject.
Nothing Good happens to an engine that is running at no load.
If you are worried about the main engine, talk to boat people that put boats up for storage. If it is gas, they will drain the fuel and "fog" it. If it is diesel, care must be taken as it will run on the fogging oil but the process is largely the same.
Some people will tell you that you should run a service generator (genset, genny, APU) to keep the windings dry. That has not been the case since about WWII. The varnish used since then is not hydroscopic and it does not absorb moisture. Just like the main engine, store it properly and it will be just fine.
Matt
Matt
38,766 PostsLatest Activity: Jan 10, 2026
