pawpawlang315
Jan 22, 2014Explorer
Exhaust brake
I am having an occasional problem with the exhaust brake on my 2005 Chevy Duramax engine installed in a Gulf Stream Endura. It will at times not retract when the brake pedal is released which causes a lot of back pressure on the engine if I apply accelerator. I can crawl under the vehicle and tap the air cylinder rod assembly with my tire thumper and it will open up. It doesn't do it every time and does not seem to have a regular pattern. I have sprayed the entire assembly with lubricate and that seems to help but did not alleviate the problem.
Has anyone else encountered this problem and if so what if anything did you do to remedy it.
I would also appreciate any suggestions anyone would have.
