dougrainer
Jun 20, 2016Nomad
The Microwaves are designed to be vented INSIDE or OUTSIDE. If you want to vent outside, you get the plastic outside Vent assbly common to all regular RV vent hoods and cut the hole to the outside. You then must remount the M/W motor assbly to blow OUT instead on IN. Be advised that most OEM's, if under OEM warranty, that will VOID the warranty on that sidewall for the duration of the sidewall warranty. Any modification done to the integrity of a sidewall without approval by the OEM voids that part of the warranty. If out of warranty, then no big deal. Doug
