allbrandauto
Jun 27, 2014Explorer
you need 2 things to do the job a stud remover and heat pull the remaining bolts out if possible if remaining bolts are tight use a torch and heat bolt at cyl. head around where bolt gos thru head once manifold is off heat cly. head around broken bolt and use stud puller to back bolt off never do exhaust work with out torch for heat
