ScottG
Jun 27, 2014Nomad
There are two more ways to get it out after the manifold is removed.
Heat them up cherry red and touch the base with a wax candle. Then try to rock the bolt back and forth. The wax will wick into the threads and lubricate them and the bolt will "pop" free. (I actually watched this once - amazing!)
The next way is to simply use a cutting torch to BLOW the remnants of the bolt out of the hole. You'd think this would damage the threads but they're so heat-sinked that it doesn't harm them.
I've seen my mechanic buddy (not a "technician" but a true mechanic) perform both of these feats and he has never failed to get one out.
