KCFDCapt
Jun 27, 2014Explorer
If you know someone who has a TIG welder, or have one yourself, here is the method I have used on the Ford 460 to remove that stud. Begin by heating the stud to red hot with the tungsten and allow the heat to sink in. Repeat a couple of more times. You are also annealing the bolt so it is not so apt to snap off. Then take a nut that will slip over the remaining headless bolt. TIG weld the nut to the bolt. Allow the weld job to cool and use the proper size wrench to screw the broken stud out of the head.
