topflite51
May 15, 2013Explorer
popeye766 wrote:I went to a 4 in system starting at the Y pipe and have had significant gains in performance and I definitely have a cooler running engine. Your system sounds like it will do the same.
Thanks Neil.....
Boy your right about heat in the heads, I want to get rid of as much of that 1700 exhaust heat as possible and I sure dont want my cooling system trying to absorb it either....when running down the road Iam sure the manifolds are in the 1000 degree range..Banks hedders reduced the temp by 200 degrees....
My new system is all 2/12 with big walker mufflers. New dorman manifolds. I expect about 45 HP gain and a cooler motor. It is a true DUAL system not both running into stock type muffs and such.
Once warmed and retorqued I doubt if they will ever be a problem again.
tom
38,782 PostsLatest Activity: Aug 30, 2026
