Wavery
Jun 04, 2013Explorer
royl wrote:
I did the install with a little help from the wife. Pretty straight forward with the Banks kit, the fit and finish was perfect. It came with all the hangers,heat shields,bolts and all. That is the only way I would do it. They have did all the testing and fit testing for you so it is quick and easy. I spent most of a day with the install, I had it all removed while waiting on the system to arrive. The system including the intake mod kit and the transmission control module made the motorhome wake up and run like it should. I am pulling hills now fully loaded and towing the toad at 55 to 60 mph where I was dropping down to 40 or less before, much less downshifting and runs much cooler.
I'm assuming that you did not coat or wrap your headers..... Are you having any heat issues inside the coach? How about plug wires?
38,782 PostsLatest Activity: Aug 30, 2026
