Old-Biscuit
Dec 27, 2013Explorer III
To use the exhaust brake......turn it on
When you let off the accelerator pedal it will engage (closes...has some method of regulating exhaust back pressure) and you will decelerate. Your Allison transmission will probably downshift also slowing you even more.
When you push on accelerator pedal the exhaust brake will disengage (open) until you let off pedal again.
Great for downhill as it will help slow/control downhill speed.
Turn it ON when you want to use it....turn it OFF when you don't
I use mine whenever towing
I even use it sometimes when not towing
Simple.......push the button
Try it out...see how it works.
38,782 PostsLatest Activity: Sep 02, 2026
