Executive45
Dec 27, 2013Explorer III
A word of caution...the exhaust brake should NOT be used in rain and/or snow. Also, usually it will not engage if the cruise control is ON.....
To the OP...when descending a grade, engage the EB as your speed picks up...the brake will engage and the shift PANEL will show 2,3 or 4 depending on how your rig is configured. (a simple adjustment can be made to the computer to change it to whatever gear you're comfortable with) but the tranny may not shift down immediately. If it does not, and you are still picking up speed, hit your service brakes by jabbing the pedal..this will usually cause the tranny to downshift and your coach will slow. Once you get the hang of it, you will rarely use your service brake going downhills. Just remember to use the jabbing method on the brake pedal. You can stop by your local Cummins or Allison dealer and they will look over your coach and advise you what exactly you have and how to use it properly....Dennis
38,782 PostsLatest Activity: Sep 02, 2026
