et2's avatar
et2
Exhaust smell
I have noticed that after a period of driving our new Fleetwood Expedition 40x there is diesel exhaust smell that can be noticed in the front cab. It doesn't happen when first getting in and driving, after about an hour in the freeway this happens. It eventually goes away. The generator is not running.
We stopped yesterday to check into the camp site and the smell was present before stopping, and got really worse after not moving and did come from the rear.
Anyone experience this? Could it be the DEF cycling into the exhaust system as it does seem to go away after driving some time down the road. Even so how is it getting into the MH when going 60 mph down the road?
  • wny_pat wrote:
    et2 wrote:
    powderman426 wrote:
    How high is the CO reading from the alarm?
    Don't have a permanent one on the MH and I've yet to find the one we had in the fiver. I guess I will be getting a battery operated one today.
    If this is you 2013 Fleetwood 40x, it should have a built in one as standard equipment!
    And it is not un-common for new equipment to have power train problems such as exhaust leaks. Trucking companies keep new rigs close to home for the first 6 months because of those new rig problems. We should also expect that with our coaches and chassis.
    There is the propane gas detector, it doesn't say anything about CO detection. It has not gone off. I purchased a battery powered one today. I will test it when driving back home.
    The funny part is this isn't constant. After about 15 minutes or so it goes away. And most of the drive time it's fine. The last trip we took we didn't have this problem at all. So the first trip of 5 hrs it happened and went away, the second trip no problem, this trip after about 1 hr it happened and we were ending our road trip at about at around 1 hr 15 minutes.
    I looked into the engine compartment today with a flash light. No black spots at any connection I could see, and what I could grab seemed tight. I have a service call at Fleetwood in November, I'll have them look at it, but I'll be sure to keep the CO detector up front while driving.
  • It will only smell before def treatment not after, hence the ex leak is someplace before the def is injected.
  • Streetlight wrote:
    I you can smell the exhaust chances are you have an exhaust leak. The exhaust after DEF toes not have any oder.
    If the exhaust doesn't have a smell then what is it I smell? It is definitely diesel exhaust, I owned enought to know that smell. The exhaust should not smell all the time not just when the DEF is applied. And it's not all the time.
  • I agree with Dave. First thing I would check is for an exhaust leak between head and exhaust manifold, manifold itself, manifold to turbo, turbo to exhaust pipe and muffler.
    All you are looking for are signs of BLACK.
  • I you can smell the exhaust chances are you have an exhaust leak. The exhaust after DEF toes not have any oder.
